Discuss How’s your memory in the UK Electrical Forum area at ElectriciansForums.net
Everything moves on, usually for the best.
The ones with the loose choc block were far better that the earlier ones with terminals fixed into the base, at least you could work on them without breaking your neck then push the block back up into the base.
In another 20 or 30 years it's quite possible people will say anyone remember those dreadfull spring loaded ones, possibly called Wagos, everyone raved about them, used them everywhere, then they started failing and millions of then had to be replaced.
Yep that’s themWere they the ones that had an upturned connector block that was pushed into the cutout slot in the rose ?
Can anyone remember those dreadful ceiling roses in the 1970’s,think they were Volex, they had loose connectors, which then had to be pushed into a slot on the base,awful.
Trying to get pics but not found any yet,they also had batten holders like it.
I had forgotten all about these ceiling roses, but remember them well now that you've mentioned them.
Images courtesy of Flameport Enterprises.
Flameport Enterprises, incidentally, is John 'JW' Ward's website, and is a treasure-trove of useful information. JW is to be commended for the amount of time and effort he has invested in putting together this valuable resource methinks.
Thanks my nightmares are returning,they certainly look worse than ever.
They still look awful, my nightmares are returning.I had forgotten all about these ceiling roses, but remember them well now that you've mentioned them.
This is the offending item:
Ashley made those. I have one in the room I'm in, somewhere.I remember some that were slightly smaller than what we have now, with a separate ring against the ceiling, but I think the terminals were fixed into the plastic....
Yep. Fitted one recently on a small posh chandelier. You can still buy this fittingsanyone remember these? brilliant design if you wanted to drop the fitting for cleaning, whatever.
Lewden 'maestro' ceiling rose, I tried to get one a little while ago and couldn't get hold of one.
They used to be white, brass, chrome and possibly black
These are still about fitted a few in a lighting display in a shop for ease of removinganyone remember these? brilliant design if you wanted to drop the fitting for cleaning, whatever.
Reply to How’s your memory in the UK Electrical Forum area at ElectriciansForums.net
