Discuss Humidistat or Run on Timer in the UK Electrical Forum area at ElectriciansForums.net
Evening all. I have a customer whose bathroom is soaked with condensation after the shower has been on. its worst I have seen.
I am going to install a 4 inch 60litre/sec fan but would like an opinion on whether to go with a humidistat or run on timer. I would appreciate your expertise. Thanks
No fan, will ever clear an unheated room
Agreed..
A very widespread misconception, so many times I’ve explained the fans are not there to extract steam out the bathroom..
I call them ventilation fans, there to create so many air changes per hour..
See a lot of fans located in the totally wrong location, such as above the bathroom door, right over the bath..
An open window is always the best solution
Agreed..
Magic thanks! what is the best position for a ceiling fan in a bathroom?
Also the fan will not move the air effectively unless there is an inlet vent for it to draw the air from. Either an open window, gap under the door, vent in door etc.
A rather strange example but I was administering medication to some prisoners in a small nurses unit (behind bars). It was sweltering hot. Just the bars to dish the meds out and the main barred door to get in and out. I had the portable fan blowing right at me. The Health Care assistant then moved the fan over to the door facing the fan away from us and pointing out of the door. It pulled air from the medication hatch across the small room and out of the door and felt wonderful! When we shut the medication hatch the fan had nowhere to draw the air from and so we felt nothing.
That rather long story was to say.... fit a vent otherwise it wont work!
A good dehumidifier will remove huge quantities of moisture from a room. I'm a big fan of the desiccant wheel type. I have one here that will easily remove 3-4L of water in 24 hours.
It did when I first moved in, previous owners never replaced the faulty fan and everything was very damp. All dry now though.
Yes, Vortice Lineo 100t, (I know a lot of people here don't like those!) long overrun. Runs at high speed when light or fan switch is on, drops to low speed for the 30 minute override. works well. Very quiet.
Reply to Humidistat or Run on Timer in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi, I've just had some electrical work completed in the bathroom; I've recently refurbished the bathroom, replacing the old electric shower with...
8K
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
I'd like to find a timer switch, in a style that looks alright next to decora light switches, to control a bathroom fan. The bathroom fan...
Hi, I need to replace an old extractor fan in a house I rent out. The bathroom has a lot of black mould on the ceiling and I'm wanting to prevent...
