- Reaction score
- 4
Hi all,
I'm carrying out some fixed wire testing remedial works and I have this one to repair. This work of art is an I guzzini lighting coloum which has to cap at the top so birds have been dropping all sorts down it. Also the original installers have thrown a fuse carrier in to fuse the flex going up the colum from the 6mm swas and used connector blocks on the N & CPC. Does anyone know a fused cut out or similar that I can use to re terminate these correctly and cap off the poles?
The hole size for terminations is 185mm L 45mm w 85mm D
Any advise would be appreciated.
