Discuss I need some advice on wiring in my new 90cm hob with 2 live wires in the Electrical Appliances Forum area at ElectriciansForums.net
Nikki2o2o
I bought a new hob as we are fitting a new kitchen, we got all the other new appliances wired in, but the hob is a bit more complicated, it has 2 live wires then 1 negative and 1 earth, the wire coming out of the socket where it needs wired into where my old cooker was installed only has 1 live 1 negative and 1 earth..... I have rang around for an electrician but they all have a lot on for the next few weeks....... is this going to be as easy to install as the other appliances we wired in?
It might be, or it might not.
I suspect it is an induction hob?
It may well be too powerful for the cable that is existing.
You really need an electrician to look at this.
Sorry for the bad news.
P.s. have you a picture of the nameplate on the hob?
It should tell you how many kw it is.
Hi iv took some pictures
It is clearly labelled as to how it should be connected, subject to confirming that the installed supply is suitable for this appliance it should be connected in accordance with the labelling.
If you don't understand the labelling then it suggests that you don't have the knowledge to be able to make electrical connections in a safe and compliant manner and it would be inappropriate for us to advise further for fear of you hurting yourself or others.
Reply to I need some advice on wiring in my new 90cm hob with 2 live wires in the Electrical Appliances Forum area at ElectriciansForums.net
Metal building with living quarters the panel is on the outside and about 20 feet away from new build that will be 2x6 what type of shielded wire...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
We have an install where the client has supplied an induction/gas hob combination unit. We have a 6mm cable supplying the hob, the induction part...
