Trucker_john
- Reaction score
- 0
Discuss I trying to add a breaker & my main panel doesn't have a Disconnect, How to I add it without getting electrocuted? in the Electrical Forum area at ElectriciansForums.net
Is that panel with the picture inside your house, if so do you have a panel located outside where the meter is. That’s where your main should be and it should be 100 amps
trucker john let us know what you find after my advice, I’m confident that’s what’s going onIs that panel with the picture inside your house, if so do you have a panel located outside where the meter is. That’s where your main should be and it should be 100 amps
[automerge]1569448985[/automerge]
Do you have 2 panels@Megawatt,
Thanks for your response, The panel is outside of my house and right next to the city power meter. The panel in the pic has 2 2x50amp breakers and there isn't any other panels outside the house.
Trucker do you have a panel inside you house and 1 outside your house alsoDo you have 2 panels
[automerge]1569513608[/automerge]
Does the garage panel have a 100 amp breaker in it, if so that feeds your house panelI have another panel in the garage but i think its just a sub panel with only breakers in it. Ill look around to see if there are anymore.
@trucker the pitcher you showed us , is that panel inside your house or outside your house ?
Reply to I trying to add a breaker & my main panel doesn't have a Disconnect, How to I add it without getting electrocuted? in the Electrical Forum area at ElectriciansForums.net
