Discuss Iam a DIY' ER! in the The Welcome Forum area at ElectriciansForums.net
essie3
I have an old American lamp & am being told different reasons why I can't just change the plug & bulb! I have always understood that the wiring has to be changed as UK is greater than US! because the lamp has metal tubing to attach to the main lamp it needs to be earthed! I have new 3 core,but will I need to change all the switches etc? I would love to find a 'local' electrician who could help me,but they don't exist in central London anymore!
Hi Essie and welcome :) .
Often older lamps had exposed metal parts and unless they are double insulated (with a square inside a square symbol) they need to be earthed for safety.
If you’d like to post a pic of the lamp we could hopefully be a bit more specific.
I wish I could tried a photo but it won't come out now,sorry & thank you for your help Wilko (lamp is approx 20 yrs old!
I had a similar problem. A customer of mine had an American piece of furniture (drinks cabinet) with a strip light in it.
I changed the plug, the flex and the fitting to a LED strip just to ensure everything was UK specific.
One option I had if I couldn't get the old flex out was to use a low voltage LED tape with the driver on the outside of the cabinet, using the old flex to carry 12v
Welcome, have you fixed it?
Reply to Iam a DIY' ER! in the The Welcome Forum area at ElectriciansForums.net
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
I have a teris lamp just like the game its made of blocks that can be changed around inside each block is 4 metal coated prongs 2 have a tiny...
Hi everyone, I am a removal man and I build office furniture. The company that I work for has based me at one of there clients buildings which...
Hi: I am the custodian at Peru Public Library, Peru IL. About 20 years ago, I installed about 150 new General Electric brand electronic ballasts...
Hey, I have a shed in my garden that was built and wired up by my granddad a lonnng time ago and it currently uses 2 core/twin and earth cable...
