Discuss Identifying fault on 240V outdoor lighting in the UK Electrical Forum area at ElectriciansForums.net
Good morning,
On a current job I have an outdoor lighting system with a fault that is 240V. Problem is that it keeps tripping the rcd. It turns on for around 10 seconds and then trips. There is nothing wrong with the rcd.
How do I locate the ground fault easily using my multifunction tester?
I have opened all the junction boxes, dried with a heat gun and left open whilst I try to get the system working. Some connections were wet, and have started to go that brown rusty colour etc, but as long as they’re dry and isolated they should work shouldn’t they?
Is there a way to tell where the ground fault is occurring? Without dismantling the entire circuit?
Thanks,
Barns
Good morning,
Thanks,
Barns
DC Thumper
he should have one considering he fit solar panels .
Well I know electricians from my previous employment that didn't know how to test let alone have test equipment for all I know he just screws them on the roof and connects someone else does test. As Pete posted no/little info in profile. The question says alot.
Reply to Identifying fault on 240V outdoor lighting in the UK Electrical Forum area at ElectriciansForums.net
Hi The ground floor of my house has two lighting circuits which are each protected by an MCB. One of those circuits is just indoor lights. The...
4K
I'm working in an old house and the electrical is old cloth insulated wires. at each light box the cloth was just breaking away exposing bare wire...
Just thoughts Id share my recent fun and games on my parents farm.. The electrics are old. Its a 400yr old house with outbuildings just as old...
