Discuss Identifying items fed from 3 pase DBs in the Commercial Electrical Advice area at ElectriciansForums.net
Amp David
Mentor
Just wanted to see how others tend to label items that are fed from DBs.
Have a load of 3 phase and single phase sockets and isolators to identify and label next week and although a simple task, thought i'd see if there was a preferred way so if another sparks comes in after me, its clear to them whats what.
DBX/WAYX/L1/2/3 for 3 PH and DBX/WAYX/L3 for 1PH
Thanks for your thoughts.
that's how i was taught. only we used to use R/Y/B instead of L1 etc.
DBx/Way/Ly
Where:
x=DB No.
Way is the location in the DB
L1, L2 or L3 as appropriate.
Due to the situation as has been suggested we har R/Y/B, now we have B/B/G!
However, L1, L2, & L3 are consistent!
Hi i label the outgoing ways saying A is the DB as DBA/1L1 for a 1 phase way, and if a 3 phase way it would be DBA/1L123
Hope this Helps
Darren
Depending on the type of board, fuse or MCB.
Fused would be:
R1/Y1/B1/N for 3Ph
R2/N for 1Ph
A lot of our boards would be 550V with no neutral so B2/R3 would be common.
MCB's as the other lads have said
Haven't seen a trusty old ''Red Spot'' fuse board for donkey's years now. Once the standard for industrial final circuit distribution, as well as providing a means for sub distribution in the bigger sizes....
Did a PIR last year with loads of them. Wish they'd all had lovely clean schedules like Tony's photo though, doesn't half cut down on the time. lol.
All the sites I've been on with red spot boards have never once had a full clean schedule lol, usually just scribbled in permanent market on the inside of the door.
Same here...
Still come across quite a few of them and most of them dont have any form of labelling or as you say rough scribbling that doesnt even make sense lol...
We did a pir a few years back on large warehouse that mostly had that type of DB and not one was labelled up, took us a week just to identify circuits...
I've always used DBX-n, where n= the way number, would be a single No. for 1p or 3 consecutive No.s for 3p.
We go one step further in the factory with DBX-Y-n, X= busbar in roof, Y= board ID and n as above
Reply to Identifying items fed from 3 pase DBs in the Commercial Electrical Advice area at ElectriciansForums.net
Anyone come across this before? I was asked to do a Zs on a 3ph surge device; L1 was around 6 ohm, L2 & L3 around 0.11. Wired in singles from a...
I have retired from Solar installs and now finally looking to do my retirement project - Daimler V8 2.5. I needed some powder coating done but the...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
