- Reaction score
- 9
Hi all, I'm trying to identify a supply. Visually the supply looks like a TNS. An earth clamp is around the metal sheath of the incoming supply cable to an earth terminal block. Three phases and neutral out of the Henley unit. When I was carrying out a loop test Line and Neutral at the distribution board, my Megger LT5 lights up as Line and Earth. Telling me it's a TNCS. My tester works properly as I tested it on a commercial DB the day before. Both line and neutral, line and earth.
The whole thing is suspect as I noticed a few errors and incorrect information throughout the main room.
Any help would be appreciated.
Thank you
Thank you
