Discuss If a circuit fails a test you should? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
Mullen
hey guys,
im currently under going an electricians course in the UK but am stuck on a multiple choice question. the answer i was expecting wasnt there!
Q. if a circuit fails a test you should?
A.issue a certificate anyway as you have done the work
B.issue a certificate but ask the customer to get it repaired
C.Enter comments on the certificate but do no completely fill it in
D.Enter comments on the inspection Schedule
i was expecting 'E. Repair the fault and continue/complete testing' but alas not! help appreciated guys!
if you have a spare couple of minutes could you explain briefly why there isnt an option like E, to find/repair the fault
Under what circumstances is the testing being done PIR , MWC , EIC
PIR = B
MW & EIC = none of the answers given, you'll need to get the fault rectified before issuing any certificate.
thank you for your reply easy fox!
so under PIR this would be 100% correct? the idea of walking away from a failed test seems odd. and for my own piece of mind think i would have to rectify the problem before moving on. perhaps il get in contact with the tutors to clear up the question?
EDIT : hello all on the forums by the way! im currently going through my qualifications to become an electrician - although im lucky enough to work with an experienced electrician 3 days a week, and whilst 'training' pay isnt wonderful, the hands on learning is more than i could hope for. hopefully your a good bunch and share a passion for the trade!
for the periodic test & inspect you're there for just that; any faults etc that're found are then extra to put right.
well for a PIR it is not 100% correct, but it is the most correct answer out of those available
you would not 'ask' for it repaired.
with a PIR you are commsioned with making a report on the condition of an existing installation.
Yes you would note that a circuit had failed, but it is down to the person ordering the work what to do with that information
For example a lighting circuit with no CPC would fail its R1+R2 check (or R2 check), but that doesnt mean it has to be repaired
Reply to If a circuit fails a test you should? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi Everyone, I had a new consumer unit installed in December 2021, the electrician said that he had more testing to complete and would come back...
Firstly, please go easy as I'm still a trainee! Working on my L3 2365 I'm having trouble understanding the rationale behind adiabatics...
Hey there, Sorry I’ve just joined up. I’m a qualified electrician/Electrical engineer. Recently sat my 2391-52. My question is I had a fault...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi all, first post so go easy! This is for people who are looking for more info on the course and exams and is from my experience of doing the...
