Discuss Immersion Heater cut out and wiring in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
VWWM 1
Hi Quick question as I can’t seem to find the regulation in the BBB.
Carried out an EICR and found the load for the water tank was wired in 2.5 t and e.
On testing the circuit I couldn’t see a thermal cut out. Could you help me out with the appropriate regs regarding these observations.
Thanks in advance FC814EEF-9B8E-4E0A-A8F1-A2D1380ABFA1.jpegFC814EEF-9B8E-4E0A-A8F1-A2D1380ABFA1.jpeg
554.2.1 for the cut-out.
not sure if there is one for the cable if no signs of thermal damage.
Thanks it’s off a dedicated circuit via a FCU and timer so will just change for a DP SW and add 2.5 heat resistant cable with some clips, as the existing is Miles too long and wrapped around the shelving and the tenants camping gear!
That thermostat has a built in cutout.
is it that blob between the 2 terminals on the stat. on the pic it looks more like a screw head, but googling the stat, it does say cut-out is in it.
problem is how do you know if it works? can't test as the stat will cut out long before the cut-out.
Reply to Immersion Heater cut out and wiring in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All. Its been ages since I have been on here- Fortunately log in details stored on PC. I have just had a new boiler and 210 ltr unvented tank...
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
I have a question,about cable loadings, just to satisfy my own curiousity. The background detail is a bit long, apologies. If you get bored...
Hi Everyone, I'm New to this forum and am hoping to obtain some advise if possible please? I have a situation where a megaflow system is...
5K
