• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss immersion heater not working in Barking in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
xho464
My boiler isn't heating up water overnight like it should. I have horstmann economy 7 quartz. The timer light doesn't turn on. Boost is working but it takes a long time to heat up the water. Is it my thermostat that needs replacing?
Probably the controller ........... can you post a picture?
I'm having the same problem, here is my controller, any ideas @Octopus?
Reply to immersion heater not working in Barking in the Electricians Jobs area at ElectriciansForums.net
Yesterday moved my Mum into her new bungalow. The Hortsmann had been off for a few months I suspect. The boost worked, but nothing happened...
Until last week I had a dual tariff electricity supply with a cheaper overnight tariff. This was good for the storage heating, but now the storage...
Hi, My flat uses an Economy 7 tariff. When I use the boost heater, it works fine. But the off-peak water heater doesn't heat up the water...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
