Discuss Immersion heating dual tarrif in the UK Electrical Forum area at ElectriciansForums.net
TheCodboy
Hi all, looking for some advice. I very quickly looked at a job in an apartment block. It has a normal dual rcd board in and a, what i assume is an off peak board. The off peak is an old rewireable fuse type. It would appear that at some point there has been storage heaters in but now there is electric heaters fed from the normal board. The boost element is fed from the normal board and the bottom element that is fed from the off peak. The tails into the off peak look like they have been getting hot so I've isolated that board for now. I couldn't gain access to the communal meter room to see exactly what was going on. What would your opinion be about putting the bottom element on the normal board and fit a timer? Any advice would be welcome, Thanks!
Needs further investigation mate, type of storage heater? Sounds like dual tariff heater the main element should be off peak and the balance element on peak seems like you have it wrong way. Get your head in the book for storage heaters not always straight forward
Reply to Immersion heating dual tarrif in the UK Electrical Forum area at ElectriciansForums.net
Until last week I had a dual tariff electricity supply with a cheaper overnight tariff. This was good for the storage heating, but now the storage...
I have two supplies into a new horstman e7 box, 1 from the offpeak water heating one from standard tariff boost do both suppies go to 1 and 2, 4...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
