H
harrymonkfish
Hi folks.
Changed a Cu today. No rcd protection, Changed for a split way board. All tests were fine. Came to do Zs test on immersion heater - everything fine. Turned on DP switch to immersion and rcd tripped.
Had a good look at all cables for the circuit and all seemed fine. Disconnected immersion from switch, turned on switch and everything ok. No trip.
Is this a common problem with immersion heaters? It is quite old. Is this a case of just put in new element?
Many thanks
Harry
Many thanks
Harry
