saipowercontrol
Electricity or power has become the major part of our daily life and without electricity we cannot imagine a life today. Most of our household appliances work on electric current. We face various power problems due to voltage fluctuations. Sometimes our home appliances malfunction due to voltage problems. The solution for all these problems can be rectified only through a transformer. Power transformers or a transformer is an electrical device that is used to change an alternating current voltage from one electric circuit to another through electromagnetic induction. These transformers are employed in various mechanisms to reduce the incoming voltage or increasing the voltage of electrical equipments. These transformers have two or more windings wounded on a laminated iron core and the number of windings is based on the requirement of electric voltage that the transformer is used to supply.
There are many types of transformers like isolation transformer, power transformers, electrical transformer, audio transformer, current transformer, high voltage and low voltage transformers, step-up and step-down transformers etc. Each of these kinds has their own properties and usages in transferring voltage based on the appliance it is attached with.
Electric transformer is a device that is employed in increasing or lowering the voltage of alternating current or voltage. Electric transformers have two sets of coils called primary and secondary coils linked around magnetic fields that work as conductors. This number of windings determines the workability of the transformer. There are various forms of electrical transformers like step up transformers to raise voltage or step-down transformer to lower voltage levels that can be used in power lines or household appliances to regulate current supply and reduce electricity bill costs.
