Discuss Impulse relays in the DIY Electrical Advice area at ElectriciansForums.net
abdidi
Hi. I have a problem with these relays. They are controlling the lightning in my house. Light are always on and switches are not working. Lights can be turned off only from main fuse. Lights have 24v transformer. Is there some kind of trasformer or fuse controlling the relays witch can be broken?20200914_085209.jpg
Did all the lights stop working correctly at the same time? What is the reason for the relays and large number of circuits - is this a very large house?
House is about 200 m². Relays are controlling microswitches for lightning at kitchen, livingroom and some other places. Fifth relay from left were broken and i tried first replacing it with the left one at the picture.
And that was mistake cause its wrong relay. The right one is new and right.
Latching relays are circled red.
Also led lights inside the microswitches blacked out. Thats why i thought if there is some kind of transistor conrolling the relays.
So changing the one relay has resulted in all of the lights in the house malfunctioning? This seems strange. Do you have any test equipment?
If you put the original (faulty) relay back in, what happens?
It is now on place. New one kept hell of a noise and nothing changed. I guess cause you cant close the new relay.
Yes i have multimeter but my skills are limited at this purpose :rolleyes:
Reply to Impulse relays in the DIY Electrical Advice area at ElectriciansForums.net
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
Hi all I am new to this forum and hope this is right placed and of interest. I would like to make a setup with one or more impulse relays...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
