Discuss In what situation is it appropriate to use different colored 4/0 gauge wire? in the UK Electrical Forum area at ElectriciansForums.net
Hi All,
Background: I work for a solar and electric distribution company and I joined this forum to help myself learn about the more uncommon parts that are sold less often.
Question: In what situation is it appropriate to use different colored 4/0 gauge wire? I understand that amperage reasoning, but, for example, is there a reason why blue 4/0 wire would be used instead of black?
Hi All,
Solar I’m going to assume that you are talking about 3 phase power or single phase but all 4/0 wire is black. On a 3 phase system at 480/277vac they should be taped PHASE A is brown PHASE B orange and PHASE C is yellow. On a single phase system PHASE A is black and PHASE B is marked red. Some people use blue on phase B on a single phase system
Reply to In what situation is it appropriate to use different colored 4/0 gauge wire? in the UK Electrical Forum area at ElectriciansForums.net
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
Installing a 13K peak (10K running) generator 190 feet from the panel. The portable generator is housed in a shed at the end of the property...
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
Hello! I am hoping to learn more about powering LEDs for a custom panel I am designing.. I am not re-inventing the wheel here, but am simply...
Background: I have a ex council 1st floor flat that I bought, I moved in to care for my disabled mum and so rented the flat as I could not do...
5K
