Discuss In your country, do you use pipe to run wire through very much? in the UK Electrical Forum area at ElectriciansForums.net
We do things a little differently to you and use different materials but the short answer is yes.
Slightly longer answer is that we use very little conduit / pipe in domestic installations but it's very common in commercial and industrial sectors.
can you bend pipe?
Joe it’s not that hard to bend pipe and I’ve install pipe from 1/2 inch to 3 inch galvanized conduit. You just need a bender and know the formulas. If you truly want to be an electrician you will have to learn to bend saddles, 90 degrees, 45 degrees and 30 degrees offsets. Practice makes perfect.
Plumbers use pipe
electricians use conduit
or tube.? ?
we tend to use trunking for the multiple cables, dropping down in conduit for each accessory. i understand that Americans tend to use multiple runs of conduit.
good hardwood pipes are for smoking. bent pipes are a wet-pants problem.
Plumbers use pipe
Really I didn’t know that
[automerge]1598993327[/automerge]
Americans use EMT
Not always Mainly in industrial applications @pc1966
[automerge]1598993495[/automerge]
or tube.? ?
@telectrix If we are installing a parallel run of conduit like 3000 amps yes we run multiple conduits unless the customer wants tray cable
omg the arrogance of my trade, I swear. never ONCE did I say i didnt know how to bend pipe. I was asking people IN OTHER COUNTRIES how common is it.
Second... its not "conduit" its PIPE. if you commonly call emt, "conduit" instead of Pipe, thats your problem. we are in different parts of the planet and people use different terminology. however, 'conduit' can include PVC or MC
when you say "can you bend pipe" everyone knows what that is
I don't think people are being arrogant on here. Perhaps if you made it clearer what you were saying/asking/wanting to know, rather than just putting 'can you bend pipe?' and leaving it at that.
Joe sparky yes your terminology is very much different , I do find the American / North American/ Canadian way of doing things quite interesting...
conduit , pipe , tube ITS all the same thing
probably the biggest noticeable differences that I have seen is you use a foot bender we use a vice bender and you use screw couplers we use threaded couplers...
In Northern Ireland and I think Southern Ireland in domestic we use PVC pipe. Into every box. Never ever used capping etc. No idea why but the rest of the UK seem to not have to use it. Anyone know the reason?
Welcome to the forum joesparky
Welcome.
I think some of this was intended as humor but did not work out as funny.
Incidentally I looked up a bit more on the USA stuff after @Megawatt comment and found this stuff, fantastic:
@pc1966 you just taught me something new. I didn’t know that they even made different colors of conduit.
1 of the reasons is DEPTH. capping or oval tube can be buried plaster depth. 20mm round conduit requires chasing into brick.
Yes but why ?
Why do we make it harder for ourselves and ensure every single track etc is conduited. I've been asked and have asked it of other Northern Irish sparks for years and no one knows. Just that if you attempted to not use it here you would be laughed off site
New posts
Reply to In your country, do you use pipe to run wire through very much? in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
DIYer here. I'd like to install an electric car wall charger myself. It calls for 6/2 romex which I have. Unfortunately my panel is in my...
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
