Discuss Incoming service amperage? in the UK Electrical Forum area at ElectriciansForums.net
Basic question..jist trying to gain some knowledge.
I have 2 breaker boxes in my home. Each have 100 amp main breakers.
One is not a sub to the other. Both are serviced directly from the meter outside.
Should I assume that my house has a 200 amp service coming in? Just split between the 2 boxes? Upstsirs box primarily operates items on that floor, and 2nd box does same for basement.
Thank you in advance for replies.
There’s normally a service fuse BEFORE the meter. That will dictate the total load.
It could be 100A or more likely 80. Possibly only 60.
A 100A mainswitch in a consumer unit is just a rating. It can cope with 100A safely. It’s not a circuit breaker that would trip out at 100A.
I’ve just read you’re in Baltimore, so things might be different than UK.
One of our American members might help
Thank you for reply!. I didnt even think about the US/UK thing. But overall what you're saying makes sense.
BlackwidowZ71 I hate to tell you this but I can tell you what you have without looking at it. It sounds like You have a 100 amp panel located outside , you also have another 100 amp panel being sub fed inside your house from your main panel. I’ve never seen the power company or the inspector let you split bolt 2 separate panels on the load side of the meter without short circuit protection
Picture attached. I have 2 separate lines from meter to each panel box.
I’m sorry I stand corrected. I’ve never seen a single family dwelling made up like that
Yes sir, its bizarre. Im not an electrician, but in my 22 years as a fireman..Ive never seen a single residential home like this. My home is split foyer, and when I moved in... there were originally 2 front doors..Im assuming at one point the intent was a basement level area and upstairs seperate. I guess it would be safe to assume that I dont have total 200 amp service to entire home..just 100 amps each for both levels of home.
beginning to sound more logical. could have been 2 separate dwellings in the past, each with it's own supply, but fed by one meter.
I guess you would be 2 separate 100amp boxes. Look on the bright side, you still in theory have 200 amps and a lot of spare spaces to add something
Reply to Incoming service amperage? in the UK Electrical Forum area at ElectriciansForums.net
I don't have much room around my current 200 amp panel and want to upgrade to 400 amp. I'd have an electrician do the work but I am just trying to...
Hi All, I am new to the forum. I have a small 30 amp sub panel that once powered a green house, some lights and 1 regular 120-v outlet. We...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
I need to install a charger for an electric car, which needs 60 amp breaker. My main panel has a 200amp breaker and services 2 sub panels, both...
TLDR: In a 3 wire service are the ground and the neutral always bonded, in all subpanels? House made in 1970 has the meter and a 150 amps breaker...
