Discuss Indesit oven/grill tripping when hot in the Electrical Appliances Forum area at ElectriciansForums.net
Hi as per the title this started happening a few weeks back but when you switched the fusebox back everything would work as normal so I kept forgetting about it. Now it happens every minute so I need to resolve it. I have taken the back off the oven and as per the picture, looks like it was near to a fire.
I have been reading up and some of the causes of the fuse tripping when in use is the fam coming on (but I dont believe is does for the grill) or the thermostat. My guess is the thermostat but I am posting here to get some opinions before doing anything else. Also is there any precautions I should take to safeguard against a fire at the back.
Could be the element in your grill. It doesn't look as though there was nearly a fire that's usual for something exposed to heat for long periods
Reply to Indesit oven/grill tripping when hot in the Electrical Appliances Forum area at ElectriciansForums.net
Hi All, My 1 and half Smeg cooker recently tripped when using the main fan oven. It was during quite a long period of cooking a roast. We reset...
Hi, I bought my Zanussi ZCV663MWC cooker ten years ago, I replaced the top element four months ago and its been fine until now. When I turn the...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
I have an electric oven - now many years old. I have replaced the main circular 2.5kW oven element (ELEHY6708) several times over the years...
Hiya, I have a 5yrs old Zanussi single built in fan oven. It has recently started tripping the RCD at the fuse box. Thinking and researching i...
