Discuss Induction hob. in the DIY Electrical Advice area at ElectriciansForums.net
Okay how about a 4 pole RCD located to the side of the CUs and a 4 pole isolator located near the hob?
IT'S A BLOODY HOB, ffs. NOT A DOCKSIDE CRANE. JUST INSTALL A SINGLE PHASE 32a CIRCUIT USING 6.0MM CABLE
Diversity , you have never seen my missus cooking. The hob has a total of nearly 16kw of cooking area but the load is limited by the hob to 11kw so the total current could be around 50A so a 32A circuit not exactly ideal. Hence my wanting to spread it over 3 phases.
I've never seen someone with a negative reaction score. I feel a bit sorry for him:(
Write something sensible or at least funny @Bogart and we can maybe get you into positive territory :)
Attached is a photo of my setup. I have been asking questions on another forum but keep going around in circles. The hob has a combined load of some 15kw but limits itself to 11kw ie around 50 Amps. Yes diversity is a factor but there is a possibility that it could draw 50 amps and I think that is a lot of load to put on one of the CUs, hence my 3 phase query.
So how about I install a 3 phase RCBO coming from the Henley blocks and a 3 phase isolator near the hob?
i'd start by removing approx 16 unnecessary yellow stickers.
By the looks of it you’ve got 10 circuits spread over 3 boards?......(you could probably do the lot on one board realistically if you did some calculations) why not just re-jig them slightly and feed the hob from 1 new rcbo.....50a if you feel the need but I doubt you’ll need it.
But bare in mind it is notifiable work so you’ll need a spark in a scheme :)
" bear", "bare" is naked, just a push from the spelling gestapo.
I thought @Pete999 ran that department :tearsofjoy:
as pirate will tell us, always bear to windward of the enemy. that way, when you set him on fire, it won't fry your sails.
Reactions: DPG
Wise words......I’ll remember that next time I go buccaneering :tearsofjoy:
Reply to Induction hob. in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
hi looking to install a new induction hob to current wiring . the wiring i have is thick white probably about 15mm wide and is hard wired into...
Hi all, I’m now ready to install my hob, I have a 32A MCB with 6mm T&E feeding a 50A rated switched supply at the worktop. The hob isn’t supplied...
About 5 years ago during a full refurb on my house I re-wired the property myself (old aluminium wiring) in line with 17th edition. I had it all...
