Discuss INDUSTRIAL FIRE ALARM in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
daiplayer
HI AGAIN ALL
INSTALLING INDUSTRIAL FIRE ALARM FOR FIRST TIME. FOLLOWING INSTRUCTIONS BY MATE.
CAN SOMEONE EXPLAIN HOW THEY WORK ?
I THOUGH THEY HAD AN EOL RESISTOR TO GIVE A FIXED RESISTANCE VALUE THAT THE PANEL WOULD MONITOR. BUT WHEN INSTALLING HEAT DETECTORS EACH HEAD SEEMS TO HAVE A RESISTER IN IT.
IS THIS CORRECT ? WHY IS IT THERE ?
TIA
the device in each head is probably a diode. you may be learning, but with something like a fire alarm, you must be working under a mentor. a mistake can cause multiple fatalities.
one word.... GRENFELL.
Yes it will be checked and signed off by qualified prior to completion. Thanks for the input :)
well, you are right in the eol device.usually a resistor, but more recently a capacitor or a combination R & C. panel minitors eol. if the loop goes open circuit, then it goes into fault. a resistance across the loop. typically 470 Ω, sends it into Fire. addreessable systems are more complex.
Ah ok. So the heat alarm wont actually go open circuit when it detects fire/heat , it will alter resistance ?
Reply to INDUSTRIAL FIRE ALARM in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
I'm about to start first fixing this fire alarm in the industrial unit we are wiring, at the moment its totally empty and eventually will have a...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi, I need to extend a fire alarm, the panel is a CTEC CFP 2 zone one and currently it has a couple of apollo alarm sense sounder bases/heads on...
4K
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
