Discuss industrial unit. in the Industrial Electricians' Talk area at ElectriciansForums.net
A
alba
hi folks any suggestions?.
Going to start work in an industrial (which is quite large) unit which will be rented out.
it used to be one massive unit but has since been divided into two by a brick wall.
the problem is that the supply is on the other side off the wall. This is no problem for me, as my job is to isolate & rip out, put in high bay lighting all round unit plus emergency, and then make provisions for load and space for clients requirments. From there on the clients team is taking over. There are three boards in the unit each being supplied via a armoured through a hole in the wall to next door unit. There is no access to next door apart from going out to there front door and asking for access. I am unsure if this will comply with regs when i come to test it or the new clients sparks come to test there installation. Be glad of some suggestions (client is very unwilling to spend money!), cheers lads.
Reply to industrial unit. in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Welcome to Accelleo! We are excited to present an excellent opportunity for Electronic Engineers to work within the Security and Defence space...
