Discuss Industrial in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If that's all you have worked on, and haven't interfered with other circuits within that DB to accommodate the ring circuit you have installed tested and certified. That is correct!! lol!!
You will have to check that all earthing and distribution up to your circuit is ok. Plus main bonds etc.
I would have assumed that as an electrician, those checks would have been made before any installation work had commenced. ....Or am i assuming too much these day's?? lol!!
Ok I've checked distribution (fed directly from main busbar) checked ze (0.63 ohms for TNS) all fine and checked all bonding present and correct. Is there anything else industrial pros would check before commencing work. Thanks for help.
yep. locate the works canteen, and the company accounts dept. for your invoice to go to.
Reply to Industrial in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello, I'm interested in working PLC/ industrial controls weekend call-out work for any companies who need it. I'm based in the south of...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
I have recently completed my Level 2 & 3 in Electrical Installations & hold an ECS card, I'm struggling to find a way into the industry I though...
