Discuss Infrared heater tripping RCD on high setting in the Electrical Appliances Forum area at ElectriciansForums.net
Newtsy
I’ve just installed an infrared heater for my conservatory. It’s plugged into a socket. The heater is happily running on the second heat setting (1600W) but when I turn it up to the high setting (2400W) after a while it trips the breaker.
Any suggestions on how to solve this please?
MCB or RCD even though you put RCD in the title.
Questioning overcurrent so tell us characteristics of the circuit.
Thanks for the swift replies and suggestions. I may have solved it though. Just had a quick look at my ‘handywork’ and the cable from the unit was pressed against a hot surface (guess that’s not ideal). I’ve re-routed the cable and so far touch wood it’s fine.
What you have described definitely isnt a good idea but unlikely to cause the problem you described unless it has actually damaged the cable. Are there any signs of thermal damage?
Reply to Infrared heater tripping RCD on high setting in the Electrical Appliances Forum area at ElectriciansForums.net
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
