Hi
When we had the electrics installed for our new kitchen (few months back) we were advised by the electrician at the time to just add a standard plug to the wire of the hob extractor fan (once it was installed).
I have finally come to do this, but would like confirmation that it is safe and correct to do so.
Firstly the unit is intended to be hardwired I believe (as there was no plug top on the wire) and the wire only has the live and neutral wires in it - no earth cable. I have added the plug top, wiring it correctly, but without an earth. I have not plugged it in though yet.
I also notice that there is an earth symbol on top of the metal case of the unit. But I'm not sure what this means. Whether I'm meant to somehow earth it at this point. Or that it is already earthed (if that is possible). Or doesn't require earthing,
I would appreciate any advice to ensure it is safe to plug in. Or what I need to do to make it safe
I've added a few pics to illustrate.
Many thanks
Many thanks
- TL;DR
- Can I add a plug top to a hardwired wire for a cooker extractor fan?
The wire only has a live and a neutral
