B
Burnt Fingers
At the moment, I have multiple instruments for the tests I need to do. As I will be doing domestic mains pretty soon, I think I might get a multifunction, and I fancy the Fluke 1651.
It just seems more sensible to have one unit - continuity/insulation on comms cabling needs no calibration, my RCD tester is only to verify RCD's work before I use my tools on a customer supply etc.
Anyone use the 1651 and if so is it worthy? In fact, what do you experienced professionals recommend?
I will be fitting spurs and occasional outside lighting stuff, IR lamps etc, possibly adding sockets for my existing customers. But that does not seem to reduce the amount of verification required...
