Discuss Installing 2 additional lights on an existing circuit in a warehouse. RCD Protection? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
markthespark
Hello all, I have been asked to install 2 new fluorescent lights in a Warehouse I will be looping off the nearest existing light as these are all going to be on the same switch.
My question is, do I need to provide RCD protection to this lighting circuit as I am altering it?
Many Thanks
Re: Installing 2 additional lights on an existing circuit in a warehouse. RCD Protect
NO , YOU DON'T NEED rcd PROTECTION.
As a rule of thumb, non-domestic lighting circuits do not require automatic RCD protection, but then it depends who is maintaining the electrical system on a regular basis and accessibility to the lights.
- - - Updated - - -
- - - Updated - - -
I only wrote this once and then along came a parrot........
a norwegian blue, no doubt.
Thanks very much for the replies, I am right in saying that it doesn't need RCD protection as this is a commercial premise and it's is likely to be used by skilled or instructed persons? Or is there another reason?
Cheers
To start with, only circuits of locations containing baths or showers and those in agricultural/horticultural installations require RCD protection.
In other instances where RCD protection is required, the requirement is to protect cables concealed in walls, socket-outlets or mobile equipment used outdoors.
As you are not installing any of the above, there is no requirement for RCD protection.
The exceptions with regards to skilled/instructed persons apply to socket-outlets when they are intended to be used by such persons, or when their use is supervised by such persons.
With lighting and other circuits, the skilled/instructed person exception is when the installation is under the control of such a person.
Reply to Installing 2 additional lights on an existing circuit in a warehouse. RCD Protection? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Ok, installing a new CU with type 2 SP. The installation has an existing PV 6 panels protected by a 16a MCB at the fuse board. TBH I don't really...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
