Discuss Installing 2 swa’s in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Simple question,how would you install 2 Swa’s,they are to be clipped surface on brickwork,which will been seen,so looking for a nice finish.
Client does not want cable tray,Swa’s are 3c 6.00mm
Yea they look ok,using normal cleats,never looks right ,when clipping 2 adjacent to each other,the other way I was thinking maybe allband
What’s allband - googled but takes me to ‘All round fixing band’ and then some dude dancing on his head. (But I’ve a feeling that’s not what you had in mind!)
o
Ok,they are for air conditioning,2 supplies needed
Why do you need 2 supplies for an A/C unit? As the supply to the ccondenser (outside unit) usually is all you need as the supply to the Evaporating (inside unit) is, in most cases fed from the condenser unit, as the inside unit, is after all only a small fan.
Thinking out of the box here,all round ,might be the answer ,plastic saddles in the 18th edition,may not be allowed,unless metal ....oh dear!!
or 16mm to first unit, then 6mm from there to 2nd.
Reply to Installing 2 swa’s in the UK Electrical Forum area at ElectriciansForums.net
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
This might come across as a really daft question to people who work with cable tray quite often but as part of my AM2, I am to clip FP200 to the...
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
