Discuss Installing a light in a customers chimney (above multifuel stove) in the Australia area at ElectriciansForums.net
M
matt_h
Sorry if this is a simple question but i have been asked to install a light fitting in a chimney above a multi fuel stove. They have a stove with the flue pipe leaving the top, then it goes up through a register plate which blanks off the bottom of the chimney.
They have had a switched spur fitted ages ago ready but now need a light fitting fitted and wired in behind the lintel so that it lights the fireplace up.
Has anyone got any idea as to if this is possible? and if so any recommendations. Is it possible to insert some lights into to register plate etc or fix them onto the back of the lintel
matt, think logically, what is the purpose of the flue & the plate!!! You should install a fitting & cable suitable for the enviroment, ie, that will sustain the possible heat, mounted external / behind the lintel, or 2 of [ one each end].
There are several caged / glass bulheads or fluorescents that will fit this senario.Look under heat resistant fittings,regards piccoll
Reply to Installing a light in a customers chimney (above multifuel stove) in the Australia area at ElectriciansForums.net
My customer is having a wood burner installed. The stove installers have said he needs to get the 2 sockets that are directly behind the new...
Has any one installed spots lights above a pot belly stove ,my fear is the heat will affect the led spots and even to a certain degree the cables...
B
Prefix - I've tried to post this in automotive, but it would not let me. This may be because I have not been recently active. Apologies if this is...
I've been self employed for 4 years and have just had my second ever experience of a bad customer, where I've walked. Rewire of a 2 bed bungalow...
6K
Hi all Looked at a job today, the customer wants 6 lamp posts and about 15 to 20 70w SON floodlamps installed around the garden. There are some...
4K
