I want to add a remote room thermostat to my present central heating system.
At present I have a Draytek non-remote room thermostat which is located in the bedroom and I want to leave that one there. It has been wired/setup so that, when the heating is switched on, when the temperature drops below the rrquired temperature in that bedroom, it switches on the central heating pump,
I have also added another identical non-remote thermostat located downstairs and which is wired in parallel to the bedroom one.
Both of these work fine and will switch on the pump when either thermostat calls for heat. They both then have to be turned down to stop the pump
I would like to replace the downstairs non-remote thermostat with a remote one but, again, wired so that when the temperature drops it calls for heat. (This is because we are about to have a couple of additional radiators installed downstairs).
I am, however, unsure about the wiring for the new remote thermostat and am requesting some advice.
At present, the two Draytek thermostats have 3 wires:
1. Blue (presumably neutral) wire
2. A red (presumably live)
3. An orange (presumablyswitched live?)
These wires go back to a junction box in the garage and from there to the boiler, the pump and a simple time switch in the airing cupboard.
My new remote rhermostat is a cheap Celect one with 4 terminals:
2 terminals are together and labelled L and N (with an added note in the box stating that these should be to Permanent Live and Neutral).
The other 2 terminals are also together and labelled 1 and 2 (with the note indicating that that they should go to the thermostat on the boiler).
I can see how to connect the L and N to my present system but am confused about how and where to connect the 1 and 2 terminals so that it will operate my pump like the present system.
Any suggestions would be gratefully accepted.
