Discuss Installing hive Worcester Bosch in the Central Heating Systems area at ElectriciansForums.net
Beeg
Hi all,
I’m hoping someone would be able to give me some advice on Hive heating.
I have a Worcester Bosch Greenstar 30si with built in timer (however I understand this is an option that can be removed). I would like to install Hive but have no idea how to go about it.
I would consider myself reasonably competent at DIY electrics, just wondering if this is something I could attempt or if it requires someone with a much greater knowledge of electrics.
Many thanks
Beeg
Reply to Installing hive Worcester Bosch in the Central Heating Systems area at ElectriciansForums.net
Hi all, I have a slightly mish-mash heating set up, in that downstairs I have wet underfloor heating with an individual thermostat per room, but...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
Help please, this is my first post on this subject regarding solar panel / battery installation into house with 3 phase supply. I am a DIY level...
