Discuss Installing light switch in the The Welcome Forum area at ElectriciansForums.net
Sorry if this is in the wrong forum category but I am looking for help with changing light switch facings. I have completed all the plugs which were easy and stumped on these haha.
Thanks in advance.
It is not possible from a distance to advise what conductors go to which terminal and seeing you have limited electrical knowledge or test equipment the best advice is to get help from an onsite electrician.
As Westward says, you can't determine what conductor does what from your pictures. There are few possible configurations on how this can be connected all dependent on what each switch is doing.
Get an electrician in to sort it for you, it should be relatively straight forward and not expensive.
No more advice on how the OP can trace these connections he has limited electrical knowledge. I will leave this open to see if he responds to @littlespark and his location request.
Reply to Installing light switch in the The Welcome Forum area at ElectriciansForums.net
Hi, I have a 220v House I want to change this switch to smart switch, but I am stumped, I don't have a neutral so I had to return the switch I...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
I have a single wall switch powering 1 light and I want to add a separate light and change to wall switch to a double to power them both...
