Clueless spark
- Reaction score
- 5
Discuss Installing loft socket in the Electrical Forum area at ElectriciansForums.net
it has been known for a 13A socket in a loft being connected into the lighting circuit wher there is no socket cabling available. if it's for some low consumption equipment e.g. aerial amp. the correct way would be to fit a 5A round pin socket and fit corresponding plugh to equipment. not good pracice though, IMO.
obviously, but there are occasions where this may only be possible by chasing out from floor to ceiling on the upstairs floor. if it were me and the customer declined the disruption, I'd walk away, but others might take the easy option. bad practice, yes, but unsafe, maybe not. i remember my mother plugging the iron into a light socket using as bayonet adaptor. we wouldn't do that now, but was it inherently unsafe? obviously in that case the iron wasn't earthed, so yes it was unsafe, but did any mothers get injured. who knows.The correct way is to extend a power circuit in to the loft to supply the the socket.
It's an adaptable box being used as a joint box, as far as I can see that is most likely a lighting circuit in there so no you should not connect a socket to it (I assume you actually meant socket when you say plug?)
[/Q
that’s what I meant z. What’s the best way to get a double socket inst
£550 sounds really steep, but without seeing the situation it is hard for anyone to give a realistic quote because they need to know how easy it would be to do as mostly you are paying for skilled labour, the parts ought to be moderate cost here.
In many cases in the attic you can see the cables for the 13A sockets in the rooms below going down the wall areas, if this is the case in your situation then you could add a double socket in to the existing ring by taking one of the 2.5mm twin & earth cable from an existing socket up to the attic while pulling a new length of 2.5mm T&E up with it so you can put a socket (or two) in the joint(s) between old & new in the attic, and reconnect the new length to the existing socket you opened up.
You must follow a safe process to make sure the power is off before working on any of the circuits, safest without proper test tools is to cut power to the whole house.
Also if you are doing this you need to make sure the ring is completed so each outlet has two wires attached going along to the next, etc.
Finally you would be well advised to get a socket tester first. They cost about £10 for a basic model, or around £50 for one that will verify low earth resistance. They are not a match for the sort of tester a professional sparky would use (they cost in the £500-1000 region) but will find obvious mistakes such as L & N swapped, etc.
Good point, that would screw up my cunning plan!extremely rare in a 2 storey house. the cables for upstairs sockets cme from below in 99 cases out of 100.
Is he a DIY guy? It is always worth asking around for quotes anyway, and that sort of price is more in line with what I might expect.just had a guy quote £100 but when someone quotes me different prices like that I get a voice in my head saying is he cheap because he’s a diy guy not saying diy guys are bad but you can’t beat a qualified person that has done it for years. Sometimes your paying for the knowledge and the peace of mind that it is done 100% correct and the house doesn’t burn down with an electrical fire.
If I were you... I'd try to find someone that is recommended, by someone who's opinion you trust. I don't trust anyone, regardless of their qualifications !...you can’t beat a qualified person that has done it for years. Sometimes your paying for the knowledge and the peace of mind that it is done 100% correct and the house doesn’t burn down with an electrical fire.
That looks like a steel adaptable box which has no earth.
If you have an airing cupboard, chances are you have power in there for an immersion heater. That's what I did - there is a radial circuit which only had the 'immersion heater' (which no longer exists since the water tank was removed) socket on it, which I extended up into the loft, then back down into another cupboard (so I can power an outside light), and also across and down into my 'server cupboard' in my office. Nice and easy.if you have an airing cupboard or a fitted wardrobe/or any fllor to ceiling like enclosure, it's no big deal to spur off a socket circuit under the floor
Reply to Installing loft socket in the Electrical Forum area at ElectriciansForums.net
