Discuss Installing metal light in the Lighting Forum area at ElectriciansForums.net
Hi
I have a metal light that I am looking to install.
I was going to take a cable from my current 2.5mm lighting circuit through a junction box. I have a pull switch that I was going to add.
My questions are
  • What is the best way to add the pull switch?
  • Can I use a ceiling rose without the cover to make the connection at the light bearing in mind it is metal. A full ceiling rose with cover is too large for the metal top of the light to fit over (see pics)
  • I have some 2.5mm cable. Is that ok to use up to the light?
Many Thanks
Bulk Workwear - Clothing Suppliers for the Whole Forum Network
ChrisElectrical88
Mentor
Hi, slightly interested why you have a 2.5mm lighting circuit? Doubt you would get 2.5mm cable in a standard ceiling rose. Doubt you would fit a ceiling rose behind that fitting due to where the flex comes up from the lamps.
Get an electrician in.
  • #3
Apologies, I have just checked again and it is a 1.5mm circuit. Would it be possible to put the 0.75 flex from the light into the roof space and then connect it to the 1.5mm cable coming off the circuit?
telectrix
Mentor
yes you could do that. the connection must be enclosed in something like a wagobox, above the ceiling.
ChrisElectrical88
Mentor
Yes it would be possible if the connections were suitably enclosed and if required maintenance free.
Post automatically merged:
Like what Teletrix said 🙂
  • #6
OK. Last question. Is it best to attach the pull switch at the Wago box connection or can I run the cable from the circuit through the pull cord and then to the light?
That answers my question, yes it has.
  • #10
Guys, thank you very much for your help.
Greatly appreciated
Aico Carbon Monoxide Detectors
Reply to Installing metal light in the Lighting Forum area at ElectriciansForums.net
Top Bottom
