Discuss installing new circuit, advice on equipotential bonding in the house in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
if you install a new circuit in a farm shed, does the equipotential bonding need to be in place right back at the supply in the house (onto oil and water), or as its a seperate building does the full electrical installation certificate mean the equip zone within that shed only required??
If lack of main bonding at the supply end has no bearing on the safety of an installation you have carried out in a separate building , IMO it would be sufficient to highlight the issue on the EIC assuming the client has refused upgrading.
thats a fair point - in my opinion , the shed would have its own equipotential zone with extraneous and exposed conduct parts at the same potential - there for minimizing risk of electric shock - the e/bonding at the house would have no affect to in the shed really?
Reply to installing new circuit, advice on equipotential bonding in the house in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
