Discuss Installing outdoor lighting in the DIY Electrical Advice area at ElectriciansForums.net
Craig2810
I have a query around installing some outdoor lighting, I plan to install around 15 outdoor lights containing GU10 led 4.7w bulbs. While I am confident with fitting and cabling the lights I am unsure of how to connect them to the mains. Is it possible to simply connect them to an already existing outdoor plug socket or is it a job for a qualified electrician to connect directly to the consumer unit inside my home?
Assuming that you've wired them correctly, right cable, right cable size.... etc, then you could easily add an IP rated fused switch spur to come off the outdoor plug (assuming it is RCD protected?!), fuse at 3A. It would be unusual for something like this to need a dedicated circuit.
Reply to Installing outdoor lighting in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
We have an outdoor socket that is hard wired into the ground floor power circuit and protected with an rcd in the consumer unit. I now plan to add...
Our electrician inexplicably wired outdoor floodlights attached to side of house over driveway as "always hot", no switch. We don't want them...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
