Discuss Installing Recessed Lighting in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, sorry if this seems like a stupid post.
I have recently moved houses and want to install recessed lights in the bedroom. I have changed lighting fixtures were power is only sent to one fixture. Could I just simply send power to the first fixture and then daisy chain them using wire connectors, or is it not that straight forward? Do I need anything else besides extra wire, connectors and the fixtures?
faq-wire-light-switch.html
Any help would be grateful.
I think you should get a few quotes, possibly mark and drill out the holes for the spark.
There’s a few things that need checked like ocpd, bonding, rcd protection etc ..... that may turn into extra work that you weren’t expecting
Reply to Installing Recessed Lighting in the UK Electrical Forum area at ElectriciansForums.net
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
Led light fixture went dim. I replaced it with a new fixture and it won’t power on. I have 120v with a multimeter at the wire. When I wire up the...
Hello, 1st time post from an amateur. I have some old Habitat decorative lights that are powered by a transformer. There seems to be a break in...
