Discuss Installing vehicle charger in the UK Electrical Forum area at ElectriciansForums.net
out side the garage , are you planning the to install a charging point to the garage.Can you install it inside the garage and run charging cable through the wall or can you install it on the outside wall of the garage?
Thanks - I had seen a referral about what you mentioned - I’m skimming the IET manualThe vast majority of charging points now come with built in OpenPen protection and are suitable for connecting to a PME supply, whether inside or outside.
Hi Tim , thought that Openpen only worked with 3 phase ?The vast majority of charging points now come with built in OpenPen protection and are suitable for connecting to a PME supply, whether inside or outside.
No that isn't the case.Hi Tim , thought that Openpen only worked with 3 phase ?
Watched the video. Most useful again many thanks for your helpNo that isn't the case.
This video might help:
Reply to Installing vehicle charger in the UK Electrical Forum area at ElectriciansForums.net
