M
mec
Hi I just purchased one of these and downloaded the Instaltest 61557 manual.
In the RCD menu (No 10 setting of the Function Switch),
The manual says set the function switch to Uc,RL "Contact Voltage" or "Fault Loop Resistance and the initial menu" will be displayed, Uc or Loop message starts flashing.
This means that I should have the choice of two selections Uc or Loop, I'm supposed to be able to select either setting by pressing the SELECT Key First then the UP Down arrow keys before proceeding. My problem is I only seem to be stuck in the Voltage section and pressing the Select key takes me directly to the other setting in the Voltage menu.
Can anyone offer any advice how I switch between the two, am I missing something or do I have a faulty multi-tester?
Any HELP! would be appreciated.
