Discuss Insulating stud wall containing lighting cables in the DIY Electrical Advice area at ElectriciansForums.net
Hi
I'm renovating a 1920s terrace and have stripped the lathe and plaster off a stud wall to an upstairs bedroom. I'm resurfacing the stud wall with sound insulated plasterboard and filling the voids with Rockwhool sound insulation.
Part of the wall contains existing light cables and a light switch.
What is the correct way to insulate around the cables (or protect the cables) and switch as I understand that insulating can derate the cables?
Currently the cables are hanging down through holes drilled through the noggins so I understand they need to be supported and in a prescribed zone. I have no intention of attempting to change any wiring just to corectly position and protect the existing wiring.
Many thanks,
Neil
Yes the wiring is modern twin and earth although old colours and the property had a landlords electrical test completed just before I purchased so everything should be reasonably up to scratch
your presrcibed zones are vertical and/or horizontal from any switch/socket/ other accessory, or corners, as in the blue areas shown here.
Reply to Insulating stud wall containing lighting cables in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
Hi All, Wondering if I can get some advice. Basically I’m having exposed joist ceilings in my house and I’m in the process of slowly changing all...
Hi, I'm about to reroute cables and sockets/switches from the ceiling down to the socket height after insulating a wall. I understand this will...
Hello guys, I‘ll be building an insulated stud wall in front of a single skin brick wall (garage on the other side). There will be 2 couple mains...
Howdy DIY soldiers, first post here. My question comes down to whether it would be particularly unsafe for me to temporarily wire nut and tape a...
