Electrical2Go - Online Electrical Supplier
Discuss Insulation resistance/impendance of non-conducting floors and walls??? in the Electrical Forum area at ElectriciansForums.net
Hi guys,
Im trying to find out the instrument used and the units it measured in for Insulation resistance/impendance ofnon-conducting floors and walls
am i right in saying
Instrument used =Magneto-ohmeterand test electrodes
Units = ohms and in 0.01's
I have only ever done this test at an hospital and then I was only observing but if my memory isn't failing me I think it was done with a normal insulation resistance tester
For a normal LV installation Ithink you set the meter to 500volt for HV you set it to 1000, as I recall.But I can't for the life of me remember what values you should be expecting
I have to admit Archy how much I love the tinternet I often just plain forget that you can google most things and get the answer.......................... We are all becoming redundant
E
Engineer54
Similar tests using the same test equipment are required for both conductive and non-conductive flooring. At one time UK Hospital operating theaters had non-conductive flooring, but these day's it 's conductive flooring to meet the IT derived PA/PE earthing requirements.
Scolmore Electrical Products
Reply to Insulation resistance/impendance of non-conducting floors and walls??? in the Electrical Forum area at ElectriciansForums.net
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Top Bottom
