Discuss Intake behind bath taps in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ha I cant believe that...
Ive seen it all now...
I suppose if your sat relaxed in the bath and a fuse blows you haven't got far to go, saves getting out the bath and stumbling downstairs in the dark...instead you can just fumble around in the dark for the fuse while still keeping warm in the bath...perfectly safe... :D
Sent from my Xperia S using next doors WIFI.
Here's the board again, I'm in the process of changing it... It has Perspex sliding doors then, 2 wooden cupboard doors in front of that. There's no rubber seal or anything to keep it water tight.. What would you recommend?
That's different. Apart from the obviously barking mad location I would be concerned about condensation building up in there. Is there any ventilation or free air movement with the doors closed? Rather than perspex doors you could try those secondary double glazing panels cut to size with the correct runners etc.
Also is the possibility of putting a small fan in there with an overrun facility that triggers when the lights are turned on that would cause an over pressure in the cabinet making it harder for water vapour to enter?
I take it they didn't want it moving totally of of the room?
Are the DNO aware of this installation yet?
Surely something has to be said about the lack of safety here?
There are so many outcomes that could pass through your mind when looking at this but I think most would result in death!
Perhaps a few photo's to the DNO are required, you never know they may cut the supply until the situation has been rectified;)
:thumbsup
From a Sparky's point of view it's heaven being able to lounge in the bath, bubbles, cables, light music and being able to observe your CU and watch the meter whirring around :)
Surely if the DNO aren't told now it will be picked up when Smart meters are rolled out?
Who's idea was the perspex doors - customers? If so then surely they know or suspect it isn't safe?
It has the advantage of the occupant of the bath being able to reset the MCB without the inconvenience of getting out of the bath. ...... I like it !!! :)
Good GOD!
I have never seen anything so stupid in my life!
Does the householder actually use the bath??????
I'd be scared sh1tle55 of ever setting foot in the bath.
This is maddness, they call it madness..
I agree with telectrix.. Has to be a plumbers handy work, a spark would have least put the taps the other end..
Mind Boggling to say the least!!!
I'll never understand how someone could deem this safe???
I mean judging by the over-soldering of the pipes under the bath the plumber must have thought of future leak-proofing or am I being equally as daft? Joking....
In my opinion the plumber could be brought to rights if they can locate him, regardless of who's regulation it comes under he has created a death trap and as mentioned before once the seal goes on the bath or the tap fittings leak then it will run directly into the cutout. Building regs, DNO's regs and basic H&S have all been breached here and regardless of where exactly there is a reg against it it still comes down to a serious danger and should be brought up with the owner and reported to the DNO... its your duty as an Electrician to ensure this danger is at least looked into by the DNO with thought on re-siting the cutout to an outside wall and/or a plumber to see if alterations can be made to resolve the obvious danger.
Ignoring this could be costly and although its DNOs property and the plumber fault the fact you are doing electricals on the installation means its your responsibilty to take steps to see a solution for the hazard.
Reply to Intake behind bath taps in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Awful time of a new installation by an idiot! He spent most of his time with his phone attached to his ear held between his shoulder and face...
5K
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Hi. Have searched the net and the forums first for an answer but had no joy so here goes.. Quick background. My son just bought his first house...
I've got a bunch of old single phase BS88 1970s fuseboards in the communal areas of a converted building. All the wiring is MICC and it's buried...
