Discuss inter connected smoke alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
W
wolfiehogan
hi guys,
can some one tell me that if you push the test button on smoke alarms, are all the inter connected alarms meant to sound too.
when i tried it today only the smoke alarm that i pressed sounded.
all the alarms are inter connected.
As far as I am aware they should both sound when either test button is pressed,
all the smokes that I have fitted do but again I suppose it could differ from manufacturer to manufacturer.:confused:
Cheers Chris
Yes they do but first the smoke that you press will sound and then keep the test button pressedand the rest should follow.
We install AICO smokes and they should all sound , whichever smoke is tested. Usually within seconds. I would think all brands are the same. Maybe you need to check your connections on the interconnect side - maybe not terminated properly.
The point of interconnection is that all alarms sound when one operates. Hold the button untill all alarms sound as the other alarms take extra time to sound.
Reply to inter connected smoke alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
Hi, I have a veritas R8 alarm and corresponding keypad. Recently a powercut caused one of my keypads to stop working. I replaced the battery in...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
