Discuss Interference to LED Dimmers in the UK Electrical Forum area at ElectriciansForums.net
P
Piratepete
Hi Guys
Scratching my head on this one.
In a kitchen I've installed 3 lighting circuits. -
One row of 4 dimmable Philips 5W Mains LEDs in Downlight fittings
One row of 3 of the same
A switched circuit supplying 2 undercupboard 4W LED strips plus 6 short self adhesive LED strips fed by 3 transformers at floor level.
The 3 circuits are fed from a 3 gang switch plate containing the 2 dimmers (Vpro) and (cupboard)switch
The problem I've got is that if you switch the cupboard lights on while the downlights are on, the downlights go off and then come on again a second later. Why?
It doen't happen every time, and I can find nothing wrong with the wiring.
Cheers
Pete
Sounds like an in-compatibility issue with the two different transformers,
If the cupboard transfomers are iron cored whilst the circuitry for the other LED lights is electronic then i would suspect a start up surge is upsetting the electronic ones. try replacing the iron cored trannys with electronic types. As they tend to have smaller turn on surges when compared to iron cored trannys.
Reply to Interference to LED Dimmers in the UK Electrical Forum area at ElectriciansForums.net
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
Hi all I've been changing the halogen downlighters in my house to LED's. I have three rooms that use dimmers, two of them have two switches each...
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
The G4 110V 3W dimmable bulbs I purchased work with a dimmer. I can brighten them and dim them, but when I turn the dimmer off, the LED bulbs...
