Discuss Intermediate switch problem - Please Help!!! in the UK Electrical Forum area at ElectriciansForums.net
H
harrison2987
Hi Guys,
I have just been in a house that is experiencing problems with a hall/landing light and the 5 (yes 5!!!) switches that control it.
So here's the layout:
There is a 3 gang dimmer on the ground floor with one gang for the light in question
3 intermediate switches on the landing (landing is horse shoe shaped and there is a switch outside each bedroom door)
1 gang 3 way switch outside the bathroom.
At face value it all looks like its wired correctly. There is a common, L1 and L2 at the dimmer, and the same at the 1 gang switch, and L1 L1 in L2 L2 out at all 3 intermediates.
I can turn the light on and off at each individual switch, but when i turn the light on at 1 switch and off at another the switches then don't work at all and i have to go back to the dimmer switch to turn the light on again.
Can anyone help me solve this problem so that any switch can be operated at any time to turn the light on and off.
Cheers
Re: Intermediate switch problem - Please Help!!
first thing is to check if it's not the dimmer.if the dimmer is turned right down, then the other switches will appear not to work as the lights are controlled by the dimmer. second is to see if you have the common in the 2 way switches linked with connectors in the intermediates if the L feed is not in the common terminal of 1 of the 2 way switches. if it's into L1 or L2, then you need 3 strappers.
Cheers Tel,
I didn't see any connectors behind the intermediates, however i was getting 240v at each intermediate from one of the terminals.
I will check the dimmer and keep it turned up.
Keep you posted!!
is the dimmer turned right down? where does the L feed enter the switching system. if it's a loop in at light with L feed going int L1 of 1 of the switches, you need 3 core to the intermediates, with the 3rd core connected in each, straight through.
hmmm... my post appeared about 15 minutes after i'd posted it.thought it was dead, so, similar one follows when the forum wakes up.
Thanks again Tel, I've posted this on 3 of the forums so apologies if you see it a few times. I'll go back and look for what you've said and hopefully rectify the problem.
Cheers for the help.
did it work ok before or as it always been like this, obviously if it as never worked then someone wired it wrong, if it used to work and now doesn't time to start testing
wrong!!!!! 1 way has common & L1. 2 way has common, L1, and L2. the 2 way switches the common from L1 to L2, hence 2 way.
Has it always been like that? Or is it a new fault?
I've had this before and it was a diy bodge job that had never worked.
Either way it's not complicated.
If you are having trouble visualising how the circuit should be wired, draw it out and compare it to what is there.
If it looks the same then it's a case of continuity test till you find the fault.
I'd be surprised if it took more than a few minutes TBH.
confusion between no. of ways and no. of terminals. standard of teaching is going down to socialist levels.
One strapper is open circuit between the two switches that have to be in particular positions for the light to work, or one of those switches has a faulty contact. Should find it in 2 minutes with a multimeter.
Edit: I read your description again and it's ambiguous - there are other possibilities according to exactly what you mean.
Reply to Intermediate switch problem - Please Help!!! in the UK Electrical Forum area at ElectriciansForums.net
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
I threw away an old knackered light switch and now need to replace it. It had 4 terminals (L1, L2, L3, L4) and is fed by two blue and two red...
Suggestions / solutions please anyone? I have a 2 way switch, Hall and Landing, power being fed on Landing. When the switch is turned on, the...
