Discuss intermediate switching in the UK Electrical Forum area at ElectriciansForums.net
planning on having some two way switching put in but controlled from four places so will need to have intermediate switches I'm planning on controlling six rooms from different places inside a house so can turn downstairs room lights on from upstairs so not only two way switches but intermediate switches in between needs installing that would mean six pairs of strappers at each intermediate switch using 1.5mm three core and earth now the question is would that be too many cables at the intermediate switches or would it be ok planning all this work for security and wife's peace of mind.
many thanks for any advice.
IMO I think you should get a spark in to see if possible it can be done .
Why do you need 3 cores for intermediates, can you do it with twin instead?
1 mm instead of 1.5 ?
Have you considered using technology?
Loads of options available, rf switches are probably the cheapest and easiest option..
Or if you have loads of money there is even better options
Would the position of the switch be an issue to your wife?
For instance, due to the amount of switches one could appear to be in the on position when it is a actually off..
As alluded to above, three core & Earth cable is not necessary for two-way and intermediate switching. Just don't wire it in the conversion method but use the traditional method.
yes she would be doing that but mainly in the winter its more for security if I'm out and she thinks she can hear a noise downstairs she can turn lights on and frighten any one away.
a rampant rottweiler will do the job of frightening away.
Reply to intermediate switching in the UK Electrical Forum area at ElectriciansForums.net
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
Hi Eveyone. I'm curious about the 3 way switching arrangement similar to that seen in a hotel room. Switch at door with two additional switches...
Hi all, looking for a little advise on how to wire in a 2 gang intermediate switch. I'm doing a first fix on a house extension and it's 3 storey...
