Hello. I could do with a bit of help with a problem I have at the moment.
I have a customer who has some outdoor lights that just won't stay on. It is a big garden and the route each of the cables take are not completely known, or where some of the terminations are. The consumer unit has also been built around with a kitchen cupboard. This means I couldn't get into it!
From an internal kitchen lighting circuit switch is a switch fused spur for the outdoor lights. When ever the fused spur is turned on the MCB (it is not RCD protected) turns off. After checking the bulbs where ok and trying to piece together how the circuit was run to conduct some tests I left and returned a week later. I tried the outdoor lights and they came on. Couldn't believe it.
Had another call today to say that after the lights had been on for 5 minutes, they tripped the MCB. Once again, all bulbs are ok. The weather has been dry between the lights working and then not.
Any ideas please??
Any ideas please??
