Discuss Ipad or Sumsung galaxy in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
solarsavings
I have been taking a workbook of installations with me to sales calls to show prospective customers what we do but feel we could present things a little better if we use either the ipad or galaxy.
What do you guys use and why?
I had a Galaxy and TBH found it pretty bad, I'm not a fan of the Android OS. Borrowed an Ipad a few weeks ago and it certainly is a good bit of kit, also the larger screen will give you clearer pictures.
No Discussion, the Ipad with all the apps you can get make it a no-brainer.
I have an ipad and an Android version 4.0 tablet. The ipad runs smoother and the images render quicker, even though I have more RAM in the Android.
The Android is now used just for development testing for apps and courses/sites I create.
Not sure which apps will run on the Ipad, my iPhone now indespensible with the following apps:
Inclinometer
Compass
Camera (duuuh!)
ExifWizard (details of the photos)
Theodolite
Windmeter (we use a lot of cherry pickers for industrial site surveys)
Torch
NavFree (Free SatNav)
LightMeter (for lighting replacement projects)
SMA Sunny Dots
SMA Sunny Portal
SolarEdge (monitoring)
SolarEdge Site Designer
MetOffice Weather
Screwfix Catalogue
Screwfix Toolbox
LateRooms
oh and - McDsFinder :)
Just now need a couple of apps for the commissioning documents (use Notes at the moment) and could almost do away with paper!
Plus others for personal use
What do others use?
SolarTrack is good and free. It overlays the track of the sun onto the camera view so you can see which objects would cause shadow and when
My son has a Samsung which is not bad but I have the iPad 2 which beats it hands down so long as you don't require Adobe Flash which the iPad doesn't support.
In terms of apps for iphone. Have a look at:
Sun Seeker Lite (free) or full
Altimeter (free) - useful for wind calcs.
Solmetric iPV - It looks expensive but I find it hugely useful for horizons and shading objects. If you live in a hilly area, you would be surprised at the difference horizon can make when properly input into PVsol.
Reply to Ipad or Sumsung galaxy in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi guys, Had an issue at a recent survey where doing a quick check and found we had pme with a reading of 0.44 ohms. Called the network and they...
Why is the word 'competent' being over used to describe what was once just 'qualified electricians' with experience? Is it to promote proving you...
I bouught a Nissan Townstar EV and have found what I consider a theft problem All previous vans I have had allowed the driver to enter and exit...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
