Discuss IR test on shop best way to test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
marty1234
I have to test shop today but it not possible to disconect every light fitting (1200 * 600 fittings)and other ones with electronic ballists . Also i can not get in to disconnect the tillsand other sockets what do you think the best way to tes the IR on this
with the lights test between live cinductors and circuit protective conductor ( neutral is a live conductor )
so link live and neutral at the last point on the cicuit and test to cpc
any cicuit you can not isolate mark down in the box extent of limitations
( prior to testing the extent of testing and the extent of limitations should be agreed with the person ordring the inspection )
Reply to IR test on shop best way to test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
In my line of work it's very rare that I ever have to change a DB. I'm largely in maintenance; occasionally have to add new circuits etc. so in...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Hi, I carry out PAT testing on landlord appliances for letting agents in rented accommodation. Occasionally some of the items I cannot access...
Hi, I'm a little confused confused is someone can shine some light on the amendment 2 way of doing IR. I know you have to do one 1st fix at 500V...
